FREE iPhone Guide, features hundreds of How to guides, Tips and Tricks.
samichaudry
Hi guys, I recently developed an app called 'Shortcuts - the iPhone guide'.
- Shortcuts is an essential guide for all iPhone users which helps you get the most from your device.
- Shortcuts features hundreds of How to guides, Tips and Tricks. Shortcuts will help you use your iPhone more efficiently.
- Shortcuts even explains how to get the 'Emoji Keyboard' for free, don't waste your money on buying 'Emoji Apps'.
I've just reduced 'Shortcuts - the iPhone guide' to FREE for a limited time only!
So why not take a look, it's FREE after all... App Store - Shortcuts - the iPhone guide
Sami.
Did a quick look at your app. You state that having "Push Email" turned on is a battery drainer. That is 100% incorrect. If you have ONE push item turned on, then you might as well have 1000 push items turned on. And since iMessage uses the push system, having push email on doesn't affect battery life one bit.
Just a heads up.
