Hi there. I watched the video in the link, and I'm not too sure what you are seeing in Amazon. It looks normal to me on the recording. Does the recording of it look normal to you? Perhaps you can record the screen using the camera of another iPhone?The answer is in display zoom.
When I start that , all apps start working better , and amazon losses lines.
And here is why.
Everybody keeps saying that all ios apps are more or less the same but there is a resuloution diference and there is a screen size difererwnce.
When you take 0.2 inch screen , and zoom it , screen starts acting like its 6.7 inch screen and issue is gone.
So all developers huold chage that settings in their apps and apps will work just fine.
No no , its not a trick of eye.I kinda see what you're talking about now, I think I might have perceived it as a trick of the eye type of thing more so than a display issue. Let me know if anything fixed it for you other than the zoom.
Now , when i submited bug to amazon , and said to them that when I turn on zoomed screend issue goes away , this thech guy from Amazon said to me that its a scaling bug. When zoomed screen is on , resolution goes down a bit , a pixels densety goes down a but , images get a bit larger , but , even on standard mode when you enlarge photo , these lines goes away , so the tech guy from Amazon said , that there is an increae in resolutin and pixel size , also sceen size 6.7 vs 6.9 that app manufcurers try to avoid fixinig by leaving UI the same , and that is how you get SCALING ISSUEI kinda see what you're talking about now, I think I might have perceived it as a trick of the eye type of thing more so than a display issue. Let me know if anything fixed it for you other than the zoom.
It makes sense yes , but I would like that someone else cofirm this lines.I kinda see what you're talking about now, I think I might have perceived it as a trick of the eye type of thing more so than a display issue. Let me know if anything fixed it for you other than the zoom.
And again , TNX MAN.I kinda see what you're talking about now, I think I might have perceived it as a trick of the eye type of thing more so than a display issue. Let me know if anything fixed it for you other than the zoom.
