Help
Help
bosquoyruth
Hi there, I am hoping i've come to the right place for help and not going to make a fool of myself by doing somthing dum with my new phone........Whats happened is i was setting it up earlier on and i plugged in the cables etc and yes it loaded on itunes but......... it seems to have loaded my fiances itunes account and not mine so when i go to buy an app it is asking for his itunes password etc and confirming his details..... can anyone tell me how i get my own account registered to my phone!
Just go to Settings>Store then log out. Login with your itunes. Next time you sync be sure and log into your Itunes on the PC before you sync. Because you can only sync with one account. If you don't it will erase all the apps you downloaded from your account.
many thanks
I have it sorted, dunno how it loaded up with that account!
Thanks very much x
