Help
Help
beloved0024
HOw do I find what I've downloaded? I down loaded spring board can't find it. I've downloaded android lock, can't find it. Please help
Open Cydia and allow it to load and update all Packages to update. Then touch "Manage" at the bottom, then "Packages". There it will show you everything that you've loaded via Cydia.
Oh, ok thanks. I'll give it a try.
Most things downloaded from Cydia are put in it's own section in the Settings app.
Some packages have no icon, and nothing to configure at all (Example: SwipeShiftCaret, NoStoreButton, TV Tube Sleep).
Some pacakges do nothing but leave an app icon, and do not show in the Settings app, Like WiFiFoFum, or ProTube.
That is what happens with most user friendly packages after installing.
Debsguy100402 said:
Will Cydia apps and tweaks affect the way any regular apps perform?
No. Not unless that is what they are specifically for.
