How much charge should the battery lose in stanby
olefin
Say battery is fully charged, all apps been deleted, not using Push Notifications, Wifi turned off, Siri turned off?
My devices when on standby loses about 1-2% overnight depending on how long "overnight" is, which is anywhere from 3 to 11 hours. No push notifications, wifi/data turned off, Siri is off.
Thank you.
Then suppose mine is not far off, it loses about 2 to 3% per hour at night in standby. Not as good as Apple advertises but good to know I'm not the only one.
Battery usage differs for every user and device. You can have 2 users with the identical setup with one having a battery problem, and another without.
I can charge mine to 100% just before bedtime, then next morning after about 8 hrs it will be down to 84 to 76%.
Of course this is much worse when roaming, then it will loose 50% overnight on standby!
Our iPad doesn't seem to lose any charge in standby.
Believe when it gets time to replace this phone I'll check out the other brand.
There are also other factors that can play into the scenario, like if your device is jailbroken or stock, iOS, etc etc. Then again, we have users that have identical setups but have completely adverse battery life as I've said earlier. Also let your battery adjust for a while before saying "my phone's battery is stupid".
