yes and d1
usually i can follow directions, but i have never seen that type of file
I'm pretty sure Verizon can back up your contacts and load them onto your Iphone. As for me anytime I get a new phone I write down all of my contacts name, phone number, and any other information I have on them on paper and manually put it all back in. Why go through all the trouble? Because I'm just that hardcore. Ok the real reason is that I'm paranoid about something not transfering over properly so I'd rather do it myself. :iphone4vert:
Only problem with having Verizon transfer contacts over is many people especially tech savy ones are rooted. VZW wont touch your device if its rooted I do not believe.
True, but you can unroot or load a ROM that is based on the most current official build and I can pretty much bet they won't be able to tell a difference on the rooted issue.
Well that's interesting. I can assume you can also reset the phone to factory settings and then go from there? I've never rooted my phone so this is all new to me.
Actually rooting kills the option of factory resetting the phone. The way the root works out, you actually get into the true main program of the phone itself. There is a process of flashing two files typically and it takes it back to stock. But honestly, most of the techs don't know what to look for with rooting and if they do, as long as there is nothing wrong with the phone and they are just pulling contacts off, there really shouldn't be an issue. The factory ROM's you can install are the exact factory ROM's that come from Verizon just tweaked a little. But honestly nothing to worry about.
