I would like to know how do i upgrade the jailbreak from 4.1 to 4.2.1, i tried both Greenpoison RC5 and RC6 and it goes through the motions of jailbreaking but it remains on 4.1?
I "shift restore" the 4.2.1 firmware and got the expected 1013 error in itunes i then went and used RC6 and it completes the jailbreak but the phone stays at 4.1.
I'm new at this but it should be doable.
When in Itunes checking for updates results in none being found.
Unless your preserving your baseband you don't need to shift restore. Just restore normally in iTunes to 4.2.1 (4.2.6 if on verzion) then jailbreak using greenpoisi0n rc6.
If your still getting error 1013 see this thread...
If my iphone (4.1 & 02.10.04) has been unlocked by the network, will upgrading/restoring or jailbreaking it remove the unlock, or is the unlock now permanent?
if i jailbreak my iphone 4.2.1 version.. Will my other apps and all other information stay there.. or will that get erased?
should I back-up the files first?
I have my verizon iphone jb'd with green poison rc5, to jailbreak to rc6, do I need to restore anything or what?
what does untethered mean exactly?
bump*
gaz6076 said:If it's been unlocked by the network then it's now permeant...
ok sorry if this is a stupid question but am on verizon so that means i can jailbreak it right?
bump*
ok really? anyone..
Thanks for that. So theres really nothing I could do by accident to remove it?
