How to keep CAPS lock on?
Tricon7
Orlando, FL.
If one wants to type a word or words in all caps, how is this done? I have to hit the caps lock button for every capped letter.
Addendum: Found it. Tap the shift key twice.
double tap the Shift button and you'll be able to write whole sentences with capitol letters.
As a futher note on the subject, you can also dictate in all caps as well.
If you say "All caps" then your sentence, it will make the next word all in caps and then the rest of the sentence lower case.
If you say "All caps on" then your sentence, it will make every word in the sentence capitalized until you say "All caps off".
I believe it's on by default, but for others reading this who may not know ...
You also have to have the option "Enable Caps Lock" set to ON in your settings. To do: go to Settings > General > Keyboard and make sure that line is set to on.
Jut in case someone tries the double tap and it doesn't work (because it won't if it's not set). FYI.
Marilyn
