- Feb 12, 2012
is there any way to recored my iphone screen or put my iphone screen on my pc like so i can view it on the pc without jailbreaking
THEPROTVSHOW said:is there no other way like using vnc or an app for it i want to make youtube videos
THEPROTVSHOW said:wait is there a way to put my iphone on my tv then use a cap card
OK, I' haven't done this before, but I believe you can get a "capture screen" by holding the Home button AND Power button at the same time. It will "flash" on the screen and will save it to the Camera Roll. (This is confirmed) From there you can get it onto your PC if you can manage to get iTunes to transfer it for you. Few mortals are able to figure iTunes out......
do you know how to do this
