iamkimosabi
That's horrible. Only 3 hours of use?
Mine is about 30 percent with about 5 hours of use.
Hey iMarilina, any update on the battery life yet?
Look at the stand by time. Today, still on that same charge with 24% left and 2 days, 10 hours stand by time. Stand by time is my gauge for battery life not use. Use is just that, use, I expect the battery to drain under use. People here complaining of poor battery performance are relating that to how much battery drain they have while the phone idle.
Update!
My battery life has drastically improved! Doing both the Siri and calender fix has more than doubled my battery time. I used to get 50 percent at about 2 hour of hardcore usage. Now I get about 80 percent on 2 hours of hardcore usage. Then again I also did the battery drain completely and recharge to 100 percent trick a few times too, to train the old battery on my 4s. I'm a happy camper and I do suggest it. Good find!
Bah, I went back to 5.0.1 to wait for the jailbreak.
I am not gonna give up Siri just to have a bit more battery, nor am I going to give up anything that I want open.
I am just going to charge it more. So be it![]()
wymi said:What happened with the ios 5.1 beta 3? Was your battery life any better at all?
Interesting to note that actual phone call use does not seem to be reported in the usage stats. At least for me. Try it out and see your results.
Phone call is part of usage time. Unless you download some apps from the store to have a full details of usage time.
Correct it SHOULD be. But it doesnt seem to be is what I am saying. Example the other day (light day) I was showing 30 min usage and 15+ hr standby, but I knew I had been on the phone for a while. Looked back at call logs and was actually talking on the phone for 60 minutes. Added to that are a few emails, txt, download an app and play with it some. etc. So I started watching and it seems than none of the actual talk time is showing up in usage. I really do not have the battery issue per se since 5.0.1 but this usage reporting is just not accurate.
Strange issue. Usually, either the battery usage stat is working, or you plug in charger even for a second and it will read - - or 0 0
But not count phone call or email as usage time?
Do a hard reset see if it will fix it up or not.
upI've left my screen brightness setting on the default ("auto-brightness" ON) although I'm not sure I've ever noticed a difference between day and evening use.
Anyone play around with this?
In other words, has anyone turned auto-brightness OFF, adjusted the screen brightness manually, and seen any significant battery life improvement? (I'm not sure, logically, if it would or would not result in better battery use, as I'm not sure how much difference there really is day to night)
Thats incorrect if you plug in the stats wont reset until it reaches 100% full charge.
