eddieg
Turn off all "Push" notifications in settings. "Push" will check for updates to e-mail, messages, etc. constantly, running down the battery. Check every programs settings and turn "Push" off. Turn off everything in "Locations". Only use the "Push" settings and "Locations" settings when you really need them. The easiest way is to turn off "Notifications" and "Locations" in settings. And, yes, the battery will get somewhat better after a few charge/discharge cycles.
Yes, that's exactly what i did. i even closed all the running apps in the background by double tapping the home button etc. now i left my phone 10hrs in sleep mode and from 18% it went down to 12%. i think there's a little improvement? but when i turned it on with normal usage, in no less than 30 mins from 12% it went all the way down to 3%. is that normal too?tnx
10 hours off sleep and you lost 6% thats a little high should be 2-3% in that amount of time. Keep an eye on it maybe it will get better.
