VMonk
- Aug 6, 2010
this will be good to see how long of battery life i get out of this thing, my 3g did not last long but with everything turned on, also how long do you charge your phone before using it? or do you just use it first day while plugged in charging? i was told thats bad for battery life doing that and to leave it at least 12 hours, i usually try for 24
did anyone else do this? at least for the
initial charging when you first got the phone?
should i/we?
Anything I've read about lithium batteries is that the 1st charge is no different than the 5th, the 50th, the 100th, etc. All that matters is that you drain it completely once a month or so.
Thats what i also heard...
