iPhone 4s (5.0.1) battery draining extremely quickly lately.
xChase
I'm not sure which tweak did it, but ever since I installed something from Cydia, my battery has been draining incredibly fast (3 hours usage etc) and it's getting increasingly hot. I'm going to post what I have installed, and hope for some insight. If anyone can recommend tools or tips etc for me to figure out this issue, that'd be GREATLY appreciated.
iPhone 4s apps/tweaks - Imgur
Thanks!
Why don't you start by uninstalling your most recent tweaks? It could be that simple. And also pay attention on the tweaks you are installing if they are compatible with your iOS or not, it's very important.
Do you have anyring and f.lux installed? If yes delete those,cos they made my battery to drain fast. Another thing is to not using the game center sign out if you are in. Hope this helps.
