iphone 4s stuck in recovey mode after attemp with ios 6 update NEEED!!!! HELP!!!!
-1 is commonly known as a bricked device. Thy arouses from the baseband chipset for the most part. Sometimes it might just be a hiccup that you can troubleshoot by going into safe mode or by forcing the device to boot a patched kernel or if you force it into recovery using progs like RedSn0w and force it back out of recovery. Do you have TeamViewer? If you do I can help you take a look at what might be the problem. It would help if you had a webcam of some sort so I can see the device physically
The new redsnow doesnt support iphone 4s, and is there any way to fix my phone if it is corrupted.
Define "corrupted". And it'll probably yield better results if you started a different thread so not to confuse
