iPhone 5 white 64gb
The battery percent won't change until I reset it.
It won't charge unless I shake my iPhone a few times.
Battery adhesive has become loose.
After restating the phone when leaving it to charge to check the percentage of battery remaining, my phone the proceeds to stay on for a minute or two, then it will have striped lines across the screen or the picture will go negative as the screen fades out to black 5 seconds goes by and it will reboot itself, only to restart the process a few more times before about the fifth time it stops. I've tried turning off the battery percent and then hard reset and then turning it back on. Still nothing has changed. I've hard reset multiple times as well as drained the battery fully, and then charging to 100%. It all started by my phone not charging but it would say it was charging. Then about a few days later the percent stopped registering correctly. And after a few more days it started the reboot after fading out a few times. I have also tried to restore to factory setting and removing and then replacing the battery to make sure it wasn't a lose connection of the battery. I'm all out of ideas and can't find a solution on google or forums.
