jailbreaking help
Iphone Guru
So I just jailbroke my phone which I have done faithfully for the past three years, now for whatever reason the signal meter is staying at one bar does not fluctuate up nor down, what is going on???
i will try but im just hoping that i will still be able to jailbreak when my firmware is update with out the jailbreak
So I tried to restore it and that didn't wOrk tried to downgrade and that didn't work so what now, I thought I was the iPhone guru and this none sense just keeps getting worse!!!!
What didn't work? The signal or the restoration? If it's the signal, i think that u are having a hadware issue, if it's the restoration, i think that you can still restore it factory reset.
