Light Leak ear speaker Verizon iphone4?
Paemt104433
So I was using my phone in the dark lastnight and I noticed a small dim line of white light on the right side inside the ear speaker. That normal?
Never noticed that kinda thing on my phone. Are u able to see it again and again or you just fortunately saw it and that's it.
Yeah I can see it but it's not horrible I called apple and they're excuse was that since the Verizon model is made diff that there is possible light leakage.
Do u think it's something to be concerned about? Other than ghat my phone is remarkable.
Thanks. I been checking out the AT&T models bit it didn't have this problem.
Well u just checked my friends Verizon iPhone and he has the same problem... Hmmm guess it's the way they are made.
There are lights all over the device, I don't think it can disturb, specially that you can only see it in dark conditions. But as you are worried about it, then pay a visit to your carrier or to apple store and hear what they say after seeing those lights by themselves. If it's normal they will tell it to you.
Ok well i guess its not that big of a deal cause like i said the phone works great.
That's the trick! If the phone is working fine, then disregard the small stuff. We can always find "something" wrong with anything.
