Making the switch from android to iPhone and need a ill help
meaker
So finally thinking Me and my gf making the switch but need some help. We use the same computer and my itunes(music). I want be able to sync my gmail contacts to iTunes and hers to but not to mix each other contacts up. So getting my contacts to the iPhone easier. I understand we need to cloud accounts for back up but don't know if I can keep contacts separate, apps separate but same music.. Can someone shed some light to how? Thanks
I sync both my husband and my computer through iTunes. You can choose preferences and I BELIEVE it recognizes them as two separate devices. Correct me if I'm wrong anyone. If you have google accounts you can sync your phone directly to google with contacts so that wouldn't matter anyways.
iPhoneMommy
~Tech Obsessed Mom~
iPhone 5 - Black - 16GB
"Be nice to people on your way up because you'll meet them on your way down." - Wilson Mizner
Tapatalk Yo! :)
Make sure you both have seperate Apple ID's or it will all get mixed up
Choose to manually manage music in iTunes
Hook or Skull know Gmail better than me so hopefully they will chime in to help you there
My contacts and calendar are set up as an exchange.
Settings > mail contacts calendars > add account > exchange > enter in all your info and use m.google.com as your server.
Make sure you only sync the contacts and calendar not mail.
Hope it helps!
iPhoneMommy
~Tech Obsessed Mom~
Tapatalk Yo! :)
Hope it helps!
iPhoneMommy
~Tech Obsessed Mom~
Tapatalk Yo! :)
Thanks that work on my gf iPad so should with a phone.
But still wonder how iTunes will work. I have iTunes on the computer and was wondering about syncing the music to a iPhone. I guess it would just let me transfer music but what happens if she wants to buy something thru iTunes on her phone. Won't it be under a different account?
Very simple to change accounts in iTunes.
Just click Store>Sign Out
Then click Store>Sign In
And change account
Now you can have separate settings each for purchases.
Sent from my iPhone 4s using Tapatalk
Even though your purchases are under different accounts if they are in the same iTunes you can both share them. Or not.
yeah, Make sure you both have seperate Apple ID's or it will all get mixed up,thank you
