Need Help about how to update..
Installing TU
You will need to download the latest version of TU for either OSX or Windows from - The Firmware Umbrella - TinyUmbrella
As a MINIMUM you should be running 5.00.9. Do NOT use anything older than this as previous versions had some bugs.
what is the meaning of 5.00.9...
is that IOS?
mine was only 4.1 can i still use this method?
Your blobs have invalid APTickets, so you won't be able to restore using them.
then what will i do..?
is there any other way to upgrade my Iphone to a higher IOS?
any method or any way for me to update my IOS?
or i will be forever be in 4.1 IOS
any help will do..
if you think of any method that will allow me to update my IOS and Iphone can still be unlock.. can you teach me so i can do that..
or how to fix invalid APTickets
thanks
i cant even downgrade my ippad base ban lol
need help my stuck
any help will do..
thanks
Jaypee--
This is your final warning of repeating duplicate questions in different posts as well as bumping threads to create attention!
I have just deleted your 4th post in another thread you just create asking about downgrading your iPhone--this is against forum rules!
Please keep your posts that are related to your issue here to avoid multiple threads running. This creates confusion and will make it hard for members to follow.
Ski ~ iPadforums Moderator | iPhoneForums Moderator
ok i'l just wait for some one to reply on me..
thanks and sorry about that
Iphone 3GS 8GB black
Version: IOS 4.1 (8B117)
Firmware: 06.15.00 (Ipad Base Band)
already jailbroken and unlock using ultra snow
SHSH Blob 4.1 , 6.0.1 , 6.1.2
With Invalid APTickets (Don't Know Why)
With New Boot Room
UPDATE
heres what i did..
sir willerz2 advice me that since i have Invalid APTickets the only option i have to update my Iphone 3GS is to completely restore it using itunes
but first i need to "Downgrade my Firmware first Since im Using Ipad Base Band 06.15.00"
Because I will have an errors if i just restore it using itunes when i still have my Ipad base band .. so i need to downgrade it first b4 i restore using itunes...
i make a folder name Pwnage on my desktop.. i put it there the latest redsnow zip file. unzip it and put also the 6.0 IPSW for IPhone 3GS i download same folder..
then i run redsnow as Admin
so as instructed i downloaded 6.0 IPSW for Iphone 3GS
use latest Red Snow
Extra
Select IPSW (i Pick 6.0 for Iphone 3GS)
ask me if i have new boot room (Yes)
then back
(turn Iphone to DFU mode)
Jail Break
its loads up
UNTICK all (Except DOWNGRADE FROM IPAD BASE BAND)
ok
then it loads up again
my Iphone rebooted
Many White letters came up
then its stop at
"Transferring Control To JailBreak"
(NOTHING HAPPENS)
then im stuck...
anyone can help me..?
or if any way i can fully restore my Iphone to its Original state (latest IOS with no hack or what so ever)
any help will be grateful thanks
JUST PLEASE HELP SINCE IM VERY STUCK I DONT KNOW WHAT TO DO...
THANKS
"i'l just wait for someone to reply on this thread.."
problem solve thanks..
i would like to personally thanks
mr willerz2 for helping me in the best way he could
thanks
