wealthwise
- Mar 2, 2012
I wanted to change my mac addy on my Ipod touch 3g so I could be able to use a wifi, it's jailbroken I think with Limerain and th IOS is 4.1 I think. right after I tried to use Ifconfig command to change the addy but it doesn't work on older IOS from what I have read. I tried SpoofMac as well and it didn't work. So I tried the Nvram command.
""nvram wifiaddr=XX:XX:XX:XX:XX:XX" like it says here on another boards thread. As soon as I hit enter it rebooted and went into recovery mode, I successfully Jailbreaked it with GP RC5, but it still goes into recovery mode. I have a pass lock set so I need to do the hold the home button down before plugging in deal to get to DFU in Itunes. I can reset if necessary but I would rather not since I have nothing backed up. One good thing is I can still access the sbsettings, I tried to respring, reboot, safemode and no luck, I can see that both Wifi and SSH are on and I have an IP adddy also it appears that an ap that I had left on is still working. I have tried Irecovery and the commands went through but no fix, I tried Tiney Umbrella, but it won't work. I have some blobs saved. I tried Fixrecover for windows no dice, I wonder if I'm doing something wrong or if there is something else I haven't tried. I would also like to know if I do need to restore and I downgrade or Upgrade the IOS what IOS would let me either change the Mac addy or spoof it?
Thanks for any help.
