Need help restoring my device, thanks
If you let the iPhone sit, it should exit recovery mode on its own after 15 minutes unless something else is wrong.
I guess it's out of recovery, it has that connect to iTunes screen now, I just thought tiny umbrella can bring it to life. I've tried everything and ready to put it away for a while in that state and just get another device.
If you can, get RedSn0w 0.9.15 beta 1 or 3. Then attempt to PWNED DFU the iPad, then restore to a stock 5.1.1 IPSW using RedSn0w, not iTunes. This would bypass any softlocks that you may have on your iPad that could be barring you from restoring.
Thanks, I'm not familiar with the steps but I'll read up on how to do it.
