Need help with ringtones :-(
Candace said:
Yes, I've tried both. Do you know if a good ringtone app that can easily set these for you instead of going though iTunes?
You can only do that with ringtone apps from Cydia.
You can only get Cydia if you jailbreak.
actually you don't have to jailbreak you can use apps such as iphoneringtonemaker and it does everything for you
Since when do app store apps put ringtones right in your sound settings in the Settings.app?
I think I may have found it. There's a download app available that I found through a google search in Safari. It's $7.50 and you download it through Windows. Is this the one you were referring to? Want to make sure I'm referencing the same one, without breaking any forum rules.
