felipebarroeta
- Mar 15, 2012
Hello, good evening every one!
First of all thank you for keeping this amazing community of questions and answers open to the world, you really are making a difference.
Here are the details of this issue. Ive got an iPhone 3gs old bootrom made in week 37 of 2009 with iOS 5.1.1 and with no baseband. It was working well apart from the fact that it did not show IMEI, wifi, baseband info, Bluetooth, etc due to the baseband thing. It was an ipod touch with no wifi.
I read that the solution so the iPhone could get the baseband back was to restore a custom ipsw made with sn0wbreeze through iTunes and then flash an ipad baseband firmware with redsn0w.
I downloaded and restore the ipsw as indicated. The ipsw was installed in the telephone, but after working normally for about two minutes, it restarted. Then, another couple of minutes, restarted again.
Worried, I google about my new issue and found that I should install iOS 4.2.1 instead and that the process should be carried on the same way as with the previous ipws. I installed it with the same results. I think the problem is I didnt finish the procedure as I didnt flash anything with redsn0w. I flash the things and after two three minutes, again reboot out of the nothingness.
I have gone over and over again, I have installed ipsw 4.1, 4.2.1, 5.0.1, 5.1.1. I have flashed iPad bb, downgraded iPad bb. Nothing has worked, and what it worse, before at least could be used as an iPod, but now i can't do even that because ir keeps on restarting.
So here are my questions; What did I do wrong? Does this have a solution? Should I trash this phone? Is this thing hardware related? Can it be solved by me or should I take it to a technician?
I must say I have looked it up and doing this for almost eight days and havent found a fitting explanation for this. Before giving up and hammer this iPhone, I thought giving it a last shot with you guys, since you seem so knowledgeable about this. If theres any post here with this problem and I didnt see it, I beg you apologize and redirect me to it.
Very thankful in advance!
Felipe
Felipe
