- Jun 18, 2011
Ok, so I never use headphones at all, and last friday I noticed my GPS wasn't using voice. After I played with it for a while I noticed it said "(headphones)" when I would adjust my ringer volume.
Once I got home I did a google search and found this is a common problem with a common solution. I tried doing all the remedies to no avail.
I cleaned it with a qtip and alcohol, I plugged headphones in over and over again, and I did soft and hard resets. Nothing would help, and no lint or anything was visible at all.
I decided to try and restore my phone completely, but I kept getting a stupid error message from itunes when it would try and validate the software (even tho it was official) but thats a completely different issue I may need help with if we decide the phone is defective and I have to send it back.
Before I could figure out what was going on, the phone mysteriously started working again.
Well now the problem is back!!! I don't know why it keeps doing this, but I can't seem to successfully get it fixed.
I did notice today that while the phone is turning on, I can see a dim orange light inside the jack. I don't know if thats normal, or not, but once the phone is on, it goes off!
Can anyone help me???
If no one can help, I will be needing some help figuring out why itunes wont let me go official 4.2.8, so I can restore the phone, and if it doesn't fix, send it back.
Hopefully we can figure it out tho...
Thanks
Thanks
