I got the wrap and installed it today. It is VERY tight under a seidio case. But I made it work. Looks pretty good under the case. But the corners at the top are a bit scrunched up. As I get different cases I will update this thread.
Update...the side wrap had to come off this morning. After pulling the case off to fix the front piece the side piece got ripped up bad. After that piece was off the case fit much better. If you just want to run front and back it fits well with the seidio case.
The black carbon fiber looks great under my new incipio alpinestsrs bionic case. Fits perfectly under this case as it is just a rubber type case with a plastic outer frame. This is my new daily case with my seidio convert being a weekend/outdoors case.
