fireman9513
- Mar 26, 2011
I posted that the hybrid PRL is 65210 you have a native verizon PRL on your phone with 52257.I just did a hard reset, and did the #228, and now am at 52257 PRI. But, I have no idea what the Hybrid is....the only other thing I see is the ERI = 6. Can you explain more about the Hybrid?
Also....how in the heck did you figure all this out.....all I want to do is have my phone not go into searching every night, so that if an emergency happens, I can get the phone call....and now I am looking into stuff I never even heard of.
Thanks for you help.
I have had phones in the past that would act up and once I had them block the hybrid so I could get the native PRL my problems went away.
My I phone had a hybrid PRL of 65193 and I had no problems, then it updated to 65210 and it went crazy.
I also fiqure all this out by reading, reading, reading, and comprehending what I have read.
All this PRL stuff is, is on ahybrid PRL your phone looks for old alltel towers first then Verizon in areas that alltel had a stronger presence, but some of the hybrid PRLs dont work with some phones as good as others.
Now I have a question, since you have a verizon PRL is your phone working better? If not I would return it for a replacement, as mine is working fine after these adjustments.
