Volume fluctuates
Volume fluctuates
thebig429
My wife’s 5s volume goes down and up when playing music on CarPlay and or Bluetooth. Tried mine, works fine. Any ideas? Thanks
My 5S (and all my iPhones) have separate volumes for every output device or type. They even keep different levels (based on the last setting) for my Beats and my work truck both of which are Bluetooth devices. You should be able to adjust the volume on the phone while using each device to set it up.
Doesn’t matter what you use, volume goes up and down by itself
Turned every app off and now volume stayed normal. Narrowed it down to the SwiftFinder car parking app. Judging by reviews others have the same complaint.I still have to test this after I removed SwiftFinder.
