eddieg
So most of your usage is from listening to music?
sekelani said:Here is my update. Only listened to music. And light intenet browsing. No game play.
eddieg said:So most of your usage is from listening to music?
p3unit32 said:Are those numbers accurate?
sekelani said:Yeah. Absolutely. Why?
p3unit32 said:So you was able to get 9 hours usage on top of 20 hours standby?
sekelani said:Yeah. I didn't really use a lot of Internet browsing. Just a little bit. No game play, a lot of music. Like 6hours then used the phone for Internet. This forum and Facebook and YouTube , texting calls etc. what do you think?
p3unit32 said:<img src="http://www.iphoneforums.net/forum/attachment.php?attachmentid=3395"/>
Almost 4 hours left
I meant to say 4hrs later and I'm at 35%😔
Almost 4 hours left
I meant to say 4hrs later and I'm at 35%
Skull One said:I believe I have stated all along that it wasn't a hardware issue. If you keep loading your exact backup to each new iPhone 4S they give you, you will get the same results.
That's the thing skull I didn't. I loaded everything manually. Except my ringtones.
I know this is a several pages ago issue but I have to jump in and say here that Rocko's statements here are 91% false.I have been in the electronics industry for over 30 years and he's 'nearly' flat wrong. Even Apple makes clear of the proper conditioning of Li On battery. It's simple physics, gang. It is correct to say that you can't drain it all the way to zero that there's a circuit protecting against that potential. It's also true that the LiOn batteries of today are way better and more efficient than the ones in 20 years ago. But that's true of all electronic equipment. But that doesn't change the essential physics of a rechargeable battery. All rechargeable batteries, simply by physics, need to be conditioned. Once an initial conditioning is done between 2 to 3 cycles letting it go down as close to zero as possible, then after that it's only every so often as outlined even by Apple's own notes.
