eddieg
How did you take the back of your phone off with out ruining the phone?
Sent from my 64gb iPad
The 2 screws at the bottom of the phone.
iJeff said:Its due to the color of the phone. The white color acts like a flash already and with there being so much light it will come out crappy. I hope they fix this issue before the new one comes out
eddieg said:Yes the back slides off check out you tube there are tons of videos on taking apart the iphone.
I highly doubt you will find a film over the camera lens on the inside of the back cover.
I found protective film on the back of the phone case I took off. I had to replace the back on my phone due to being shattered in a fall. It had the film on it. I also found it on the replacement phone back and the instructions that game with it said to remove it which is telling me that the old back was supposed to have it removed as well.
As for voiding any warranty there is no possible way for iPhone to know if you took your back off. Or u would have driven the 3 hours to the nearest iPhone store.
I'm just letting people know what I found on my phone and just figured it might help some one.
iPhone of course
bab2010 said:There is no protective film in there, perhaps your iPhone was from eBay and was a refurbish/second hand? The iPhone you will buy from apple or from apple authorized resellers don't have that plastic film in there. Never say never though... Can happen 1 out of 1.000.000
Well all I know is my phone is brand new from AT&T not a refurb and I found the problem with mine. Also the replacement part is from apple as well. I'm not making this up.
iPhone of course
They do when your sister works for the iPhone store in Minnesota. 😊
iPhone of course
Moderation Notice:​ This post has been edited by IPF staff in accordance with the Forum Rules, no external link.
Hi.
My wife has just got a White iPhone 4.
When she uses the camera flash in a dark area the pictures are coming out very blurry and sometimes whited out or a blue haze on them therefore making the picture un viewable
Is this a problem anybody else is having or should I take it back to the apple store
Thanks
She's using it without any cover.
socialfactoryuk said:Guess the Camera Flash is just Super Powerful![]()
