Jmills87
Well-Known Member
You dont get the SHSH out of TU, you just run the TSS server and TinyUmbrella modifies your hosts file so that iTunes is directed to your locally stored SHSH instead of checking the SHSH with the iTunes activation servers.
What do you mean Sn0wbreeze wont run on your computer? What kind of computer do you have? I've used it on Windows XP, Vista and 7 with no issues. Make sure you are running it as administrator and try "XP SP2 compatibility mode" if it still wont work.
