Hi guys, does ic power belongs to the apple warranty? Thank you.
putraje New Member Joined Aug 17, 2015 Messages 2 Reaction score 0 Aug 17, 2015 #1 Hi guys, does ic power belongs to the apple warranty? Thank you.
J. A. Administrator Staff member Joined Oct 26, 2014 Messages 24,945 Reaction score 39,937 Location Apetlon, Austria Aug 17, 2015 #2 Welcome to iPhoneForums, putraje! It should be covered by Apple's warranty. You can check here Apple - Support - Check Your Service and Support Coverage whether or not your iPhone is still under warranty. There are problems with some batteries of the iPhone 5. If you're experiencing short battery life, look at this site as well: iPhone 5 Battery Replacement Program - Apple Support Hope that helps.
OP putraje New Member Joined Aug 17, 2015 Messages 2 Reaction score 0 Aug 17, 2015 Thread Starter #3 J. A. said: Welcome to iPhoneForums, putraje! It should be covered by Apple's warranty. You can check here Apple - Support - Check Your Service and Support Coverage whether or not your iPhone is still under warranty. There are problems with some batteries of the iPhone 5. If you're experiencing short battery life, look at this site as well: iPhone 5 Battery Replacement Program - Apple Support Hope that helps. Click to expand... Hi thank you J.A for answered.
J. A. Administrator Staff member Joined Oct 26, 2014 Messages 24,945 Reaction score 39,937 Location Apetlon, Austria Aug 17, 2015 #4 You're welcome.
