Skull One, you know better than that, we looking up to you for reliable info so, please continue with that. It not true that you can only install flash on older versions of Android. On top of my Apple devices I also own and use TF 201, TF 700 and Galaxy s3 all running Jelly Beans. You are correct that Flash is dead and not supported on Jelly Beans. Operative word is "support", it works. You can not get it through play store but thanks to Android you have choice to install application from other sources without need for jailbreak. And BTW, if Apple products are so flawless why do we need jailbreak?. You can download and install Flash on Jelly Beans OS device. It is available on the net. Check Android forums for instructions. Stock web browser and Skyfire are the the two of very few that will use Flash. I do not remember where but recently I read that HTML5 is going to be dead anyway.
Great work otherwise.
