Primetime
zphone said:Seems unusual. Was it at 100% when you took it off?
Then, from 7am to 12:30 is about 5+ hours so you could discharge any phone to 30% in that time with very heavy use so to tell I would really have to know what you mean by short calls and how many hours of web? What kinds of games?
Also how many emails do you receive?
Also turn your brightness down from 100% to around 60%. It's plenty bright for most uses. Just because it can go that bright does not mean that is what should be done. I mean you don't drive with your pedal to the metal all the time. You don't listen to music cranked to 100. You don't watch tv at 100% brightness and contrast. Yet when you tell people that turning their phone brightness to 100 is wrong they seem to take offense at this. dde0f
Agree. I only have my brightness at around 40%. Always under 50%. That saves juice. A lot. Also his 5 should charge in much less time then 5 hours to what he's described. That's troublesome. Even w heavy usage. iPhones at known for their fast charging times. I've always loved how fast they charge. I'd recommend he charges it one more time without using the phone at all. Just to get a more accurate reading on if he's got a defective device. Or if it was just a freak occurrence by usage etc.
