danjswartz
- May 25, 2011
At that point I go back into DFU and restore from iTunes.
So you issue is either with the ios you are using, either with the tool you are using to jailbreak. If you have another computer, you might also consider doing it on another computer to see if it works out or not.
Sure, you can use connect your phone to a mac book and disconnect it, and connect it to a windows computer, you might mess up with your itunes unless you authorise both itunes on both computers to recognize and deal with your device for u to be able to not have apps or songs etc... unsync out from your device, except that, nothing can go wrong to the device itself.Also I was going to try and install on a Windows machine but I thought you could not use the iPhone on a windows and a mac at the same time?
Just tried it on on iMac (all current software) I have never plugged my device into it before and got the exact same thing.
One thing I did notice is when trying to restore with the custom ipsw it says something in the the iTunes window about verifying restore with Apple. (it said "verifying iPhone restore with Apple) Would that have anything to do with it? Should I be 100% disconnected from any internet before I do this?
No no, instead, you should be on internet, otherwise itunes will not restore the iOS on your phone. Actually itunes is checking your shsh key to make sure that the iOS you are trying to restore is the latest one. And itunes need internet to do that. So always make sure that you have internet available whenever you are restoring your iOS.
Well, back to square one then....
I mean, for me nothing has changed. I still have the same issue. I have tried everything here, with different Macs and I get the same result. So I am back to where I was when I first posted. Sitting at the white apple logo...
danjswartz said:Just wanted to say thanks for all the help even though this did not work.
What did work was using redsn0w, booting tethered, and getting the CDMA iPhone Un-Tether from a different repository in Cydia.
Bottom line is I am jailbroken and happy.
Thanks again for the help
