How to reset setting made during 1st start-up
IceMike
Hi Guys,
I have just changed over from BlackBerry to the iphone 4s and so far loving it, however during the set up stage I selected my location as South Africa due to the fact that when I selected my actual location which is UAE the calandar was cuming up in Arabic. Now when I apply any functions such as istore the billing information comes up for South Africa and it can not be changed.
Do you guys know how I can change my location?
The quickest easiest but dirtiest way is to go to:-
1. Go to settings.
2. Go to general.
3. All the way to the bottom of the list and select reset.
4. Click reset all settings.
5. Put in your pin code if you have one.....
6. Read the warning the select reset all settings.
7. You phone will restart with the setup stage again ;)
Hope this helps you out
iNeoTom
