Hello, i was woundering if you can help please, i have another iphone 3gs, its on 4.1 and shsh is saved for 4.1/ 4.3.5 and 5.1.1 and 6.0.1. it has be unlocked and jailbroken by redsnow using ipad baseband 6.15.00, i have already created 5.1.1 firmware by using snowbreeze software (i tryed to create 5.1.1 firmware through redsnow but it comes with message saying 'memory exhusted' i even tryed using latest redsnow version i get the same message) so therefore i used latest snowbreeze and created custom 5.1.1 with no problems.
right problem i am having is,
Using redsnow, i select ipsw ( upload offical 5.1.1 firmware, then get it to pwd dfu mode, so i can upload the custom 5.1.1 firmware which i created through snowbreeze, i get an error 3194? i then checked my 'host file' delete the other line and Left this line in host file eg. .. #74.208.10.249 gs.apple.com.
still i get the same 3194 error...
option 1) get the iphone out of dfu mode, now do i have to go to tiny umbrealla select it (top left coner) in tiny umbrella and start the TSS SERVER? then conect it to itunes/dfu mode/ and upload the the 5.1.1 firmware which i created in snowbreeze? will it work?
option 2) i can use the latest redsnow and downgrade the ipad baseband 6.15.00 to 'normal basband' then try installing the 5.1.1 custom firmware?(which i created through snowbreeze) once i did try downgrading iphone 3gs which was my mate phone, baseband on 6.15.00 it wouldnt downgrade,,, as iphone 3g worked very well (downgrading 6.15.00 to normal baseband worked very well)
oprion 3) due to getting this error on itunes 3194 is it because am using a (snowbreeze) 5.1.1 custom firmware whereas this firmware was created by a different iphone 3gs handset?
PLease help me and let me know thank you for your help.
