MIC + itunes > sound out
macsoft
Hi!
I do some dance workshops, and i use the iphone connected to a mix table with a remote control to trigger the tunes.
Right now i also use a wireless mic that i connect to another channel on the mix table so i can speak over the tunes.
I wonder if there is some way i can use a bluetooth headset to do just that on the iphone.
The idea would be that i could play tunes, and simultaneously my voice thru the Bluetooth headset, would be heard over the tunes.
also, if this can't be done on the iphone, can i do it on my mac?
thank you.
