Tweak for Enabling Volume Control at Lockscreen?
If this is what you mean:
Then yes, Music Controls Pro is the only tweak (that I know of any way) that allows this.
The swipes are disabled when you have "slide to open" notifications on your lock screen.
If you use ISX, then it can be kind of a hassle. Thankfully the tweak comes with an SBSettings/ISX toggle, so you can toggle off MCSwipes when you are not using them.
Very awesome tweak. I recommend you turn task controls off so your app switcher doesn't lag. Also comes with notification center widgets that really make notification center lag. However, just keep then out of notification center. Unnecessary any way.
As I said, assign your own gesture to activate it, and it works perfectly. ;)
Not part of the subject sorry, but how did you get that Misfits Logo that is awesome!
Friend made it. Not in Cydia.
Here ya go:
http://db.tt/D1vTobSw
Can download from
safari, open in iFile, tap Unarchive, copy and paste the folder into Library/Zeppelin.
