triciao said:Wait if you already have unlimited data plans you will still have it??
Yes you will be grandfathered
xesvuli420 said:I called verizon just now (and I know that reps normally have no idea what they are talking about), and the lady told me that as long as you have the unlimited data package right now, you WILL NOT LOOSE it!!! Not after contract, not upgrading to a smartphone, not adding stuff to your plan.
She said that the only way you will loose it is if...
1. You switch to a regular phone that doesn't require data
2. You ask to come off the unlimited plan
basically unless willingly "give up" your unlimited data plan, you will get to keep it!
However ill never take a bullet for what a "rep" says, but it sounds promising, so lets hope so!
No no no, you can upgrade iPhones as many times as you want, unless you switch brands you keep it... Again this is according to "reps"
DaveM said:All I have is my personal experience to go by, so I'm not trying to start an argument by any means. I think that any change, device or contract, allows them to change the terms and you would be on the new tiered plan. As long as you just continue on month to month with your old phone and old contract nothing will change. My two cents.
