- Aug 13, 2017
Was it after you installed IOS v11?I have also been having the same issue with WiFi. Multiple networks. At home and at work.
This sounds like it has been fixed. If so: what did you do to get it working again?
Seems we are in the same boat.Yes it was. Nothing I do seems to fix it consistently.
I’m still having the issue
That's exactly how my problems started off. I then did a reset of the settings and things went seriously wrong from there.Mine forgets my home network all the time now (every couple of days), I have to select my router and enter the router's password to connect
Your new iPhone comes with 90 days of free telephone technical support. try calling and see if they can help.Thanks. I might try that. I have a Tesco near me which has a free Wi-F- service, so I'll give that a go.
The phone is fairly new (around a month old) so it would seem really unlucky if the hardware has packed up.
Thanks. Is that with Apple themselves or the service provider?Your new iPhone comes with 90 days of free telephone technical support. try calling and see if they can help.
That’s with Apple themselves.Thanks. Is that with Apple themselves or the service provider?
Thanks. I'll try give them a call.That’s with Apple themselves.
Whatever caused your problem, it's not a universal bug as it doesn't affect every user. I hope Apple can get your iPhone working properly without much delay.I still think IOS 11 has a lot to do with this though.I would advise everyone not to update until Apple has fixed all the bugs.
