How come my exp bar isn't going up when I win fights?
Ohh ok. Thanks for the info. And I don't believe in hacks. Lol just defeats the purpose of the game
when you have mastered all weapons you have equipped your level does not go up and you need to use new items...
and once you run out then thats it. i think its level 59 you can get to atm..
there are hacks out there to put the stats a lot higher but im sure you wouldent want to do that, makes the game boring quick
When you getthe infinity blade you can defeat the deathless and another robot kind of thing in the dungeons then you can choose to start a new game+ it will reset all your items and gold then you can remaster everything each time your start a new bloodline and your level cap is unlimited...
nice!, but i have a hack to make all items cost $1 ;p
Whaaaat? How did you find this hack?
This is a simple mod that will reduce the price of items in Infinity Blade to $1. Useful for those of you on newgame+ that want an item, but don't want to waste hours upon hours farming for gold.
Important! Your language must be set to English, or the changes won't show.
To Apply:
1. SSH This File( Multiupload.com - upload your files to multiple file hosting sites! ) to /private/var/mobile/Applications/(IB's Coded Folder)/SwordGame.app/CookedIPhone, be sure to back up the original.
To Remove:
1. Restore the backup.
I'm going to be looking into using the same process to unlock hidden/removed items.
