Horsehaulin
Roger that, but remember, they have to dumb it down for those that are not smart enough to understand.
Turn off push mail: If you have a push mail account such as Yahoo! or Microsoft Exchange, turn off push when you don’t need it. Go to Settings > Mail, Contacts, Calendars > Fetch New Data and set Push to Off. Messages sent to your push email accounts will now be received on your phone based on the global Fetch setting rather than as they arrive.
In general the once a month recommendation is far too often, more like once per six months will do for most people. Likely you use up your device battery in that time fully a couple of times and therefore most people don't have to pay attention to the recommendations at all if they use their devices regularly.
Skull One said:I really think they need to stop watering down the truth for the masses.
Their recommendation is SPOT ON. You do need to do it. But it has NOTHING to do with electrons needing to be moved. It has to do with calibrating iOS to understand where the battery is electrically. Lets look at the the overall situation to understand the why.
Every single Lithium-Ion battery made has a limited lifetime of full cycle charges. When you start with a battery that is brand new, it will have 300 to 500 cycles renaming. But the full storage capacity and the actual power that is delivered to the device, from that battery, is NOT maintained over that lifetime. At the end of the batteries rated cycles it will only have 80% of its original potential. So we now know there is going to be a difference over time. For iOS to understand that difference in power level it must be taught what is a FULL charge and what is a DEPLETED charge. By doing that once a month iOS gets the data it needs to properly show what 100% to 0% is on your battery in your device.
But the second you put that in print on the Apple website, people will start screaming "WHAT DO YOU MEAN MY BATTERY WILL ONLY HAVE 80% after I charge it 500 times!". Then Apple will have to explain it is 500 full cycle charges. And then people will have to understand that if you only use the battery till it read 75% left, that means you can charge it 2000 times. Or if you only use it to 50%, you can charge it 1000 times and . IE most people don't think it thru and they see 500 and 80% without doing the full math or understanding the chemistry behind the scenes.
I usually plug my iPhone 5 in when I go to bed when I want to charge it. Is it ok to leave it plugged in all nite?
Do the car chargers normally charge more slowly than the AC chargers? I'm not sure - but it seems that I see much less progress on charge rate when in my truck than when I plug direct into an AC charger at home or office. Yet both units (AC & DC) both show 1 amp charging on the faceplates. Is it my imagination? From what I'm reading here I understand that the phone is "intelligent" and receives just what it needs regardless of amp output on the charger - does this include the rate at which it accepts a charge also?
but I wouldn't recommend to leave you phone plugged all night ;(( that's a no!!
