krissigalores
I get about 5 hours usage out of my iPhone 5.. Whereas on my iPhone 4 I'd get at least a day and a half.. I've got no apps open... It's just ridiculous. Do I get an exchange or is it software related?!
Have you discharged the battery till the phone shuts off and then fully recharged it yet?
Me: Shaking my head in pure amazement. I don't know how you and I could have such different view points on this issue. But for the OP sure, try it I know it won't hurt it.
Easy. I have read the code base that collects the battery stats information in *Nix and know exactly how it works.
In fact in Android ASOP I can actually show you the exact file that contains the data and the code that uses it. iOS has the same code. Can't work any other way because if you try to read the battery level every minute you would drain it quick, fast and in a hurry because of the amount of load that it would place on it to get the true reading.
BTW, every cell phone since probably 2006 (first good feature phones) has worked this way.
I was just at 70% and I hooked up to iTunes and now it's up to 80. So are you saying it might be a good idea for me to let it power down to 5% and then recharge or is it already too late to do that?
And what you're saying also suggest of battery memory, which I know Lithium doesn't have and I know you know that as well. So I'm a bit confused by that.
But for now just answer the first question. We can get into that other stuff later.
I think I'm understanding this for the first time. The "memory" is only an indicator as to how the OS is interpreting how much remaining juice we have in the battery - which has nothing to do with the actual remaining power. It begins to give false indications of more or less remaining power relative to the use/charge cycles we put the phone through. So, in effect we have to "teach" the OS to better give us proper readings. In reality we may have more or less power remaining than our phone is telling us we have. Right? Does the way I typed it make any sense?
I'd a thought that they could somehow more effectively produce a perfect indicator of actual power left - I mean, we've "put a man on the moon for Christ sakes"!![]()
Me, I charge whenever I see mine under 80% and I'm at my desk or in my vehicles. Because I never know what might incur that might leave me running down the battery and not near a charger in the next few hours or so. For example - I broke down on a long section of lonely highway last summer. I was on a delivery trip to a destination four hours away. I was in my big box van and no phone charger (at that time) and did not think about charging my phone in full before I left. I mean - I was only going for the day and my phone, I knew was quite capable of lasting that long under normal usage.
Well, breakdown occurred. As well as almost two solid hours of phone conversations calling for help, a tow truck large enough to pull my 10,000 pound box van and calls to my guys, my customer and whatever other calls I made. So, there I was 180 miles from home on a long, lonely stretch of highway with a cellphone that had a dead battery. So now, as a result I always charge it anticipating just such an occurrence again. Though now I have chargers in all vehicles.
I'm hoping this does not shorten the life of my battery, but if Skull is right I should have no worries, right?
mike
Thank you! I'm starting to better understand the battery life cycle on my iPhoneBINGO!
Oh they can! And you would eat anywhere from 10 to 25% of the battery to do it. Because to tell the exact battery remaining, you have to put a load or in layman terms "a unit of work" across the battery terminals and then measure the voltage level. Well you can't just do it instantly, because Lithium-Ion batteries have a bounce effect as the battery gets the load put on it, so you have to wait a bit. Well you are draining the battery at its full potential until you get a stable reading. Imagine doing that every minute.
The only thing you might want to do different is every 30 to 60 days is to let the battery get down to 10% and then do a full recharge. That way the OS has a better clue to the true capacity. Otherwise the way you are using doing it is just fine. In fact the odds are you will replace the phone before you will need to replace the battery. Well unless you are discharging the battery to 80% five times a day (20% * 5 = 100% or one full cycle), then you will probably replace the battery once.![]()
